Joined: 24 Oct 2006 Posts: 51 Location: United Kingdom Thanked: 0 times
Posted: Tue Oct 24, 2006 10:40 pm Post Subject:
New consumer unit
I have a new consumer unit in place, various circuits added. All that's left is to switch existing circuits from the old unit to the new one. There is a breaker installed after the meter so I can isolate the mains but the tails are way too short to reach the new cunsumer unit, even if it were in place of the old one cos it's wider.
Any suggestions? Is it possible to extend them or am I stuck with calling the electric company out to make the connection? Any sugestions would be a great help.
Joined: 11 Jan 2004 Posts: 16480 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Tue Oct 24, 2006 10:45 pm Post Subject:
Can't you open up the "dead" side of the switch and replace the tails. Sometimes the DNO's seal them up but they shouldn't. Although it is their switch, the tails leaving it for the CU are yours.
__________________ As George Michael once said, "..if you're gonna do it, do it right, right?"
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Tue Oct 24, 2006 10:55 pm Post Subject:
A photo would be very handy.
For example, the MEM 100A DP can come in an enclosure where the load side terminals can be exposed without removing the cover (for just such an eventuality).
Posted: Tue Oct 24, 2006 11:27 pm Post Subject:
The earth leakage has an access at the top for the incoming terminals which isn't sealed, and an access at the bottom for the cu side which has a wire seal through the screw.
The attached pic... bottom left = meter, bottom right = radio teleswitch (any suggestions what this is for just out of curiousity?), top left = earth leakage trip (which I will trip to isolate the cu), top right = old cu.
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Tue Oct 24, 2006 11:29 pm Post Subject:
sounds like someone put the seal on the wrong screw........
Posted: Wed Oct 25, 2006 12:57 am Post Subject:
I'm sure that won't be necessary... if you look again, I'm sure you'll find the sealed wire has already been cut, it must have been done by the previous electrician, before you moved in.
BTW the radio teleswitch will be to pick up clock signals that turn your off-peak meter on and off the day and night scales.
Posted: Wed Oct 25, 2006 10:06 am Post Subject:
Found the earth, it feeds in from above the cu.
Next problem is that whoever wired the house left the wires out of the old cu so short there's no play on them to connect any of them to the new cu.
Help!!!?
Can they be extended and if so how? Or is it nothing but completely rewiring each of them? I hope extending is an option as the house has just been decorated and carpeted!
Joined: 05 Sep 2005 Posts: 829 Location: Hull, United Kingdom Thanked: 0 times
Posted: Wed Oct 25, 2006 1:33 pm Post Subject:
what new consumer unit have you got because i think you may have a TT supply which is rarer and requires a different CU! allthough you may get round this encorperating the old earth leakage trip (which i think you are doing), but that doesnt sit right with me it looks old and i would replace it the a CU designed for a TT (but Im not a pro, or anything near a pro for that matter)
(i guess TT based on the earth leakage trip in the picture and the fact that the earth comes in the top of the CU rather than from the supply)
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
