DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Casting a lintel in situ
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  Bookmark and Share View previous topic :: View next topic
Author Message
Antwerpman
from Belgium
Thanked: 0 times
PostPosted: Sun Feb 15, 2004 12:39 pm    Post Subject:
Reply with quote Thanks
I have a cellar on my house and a lintel which used to be above the coal chute has rotted (it was wood). I thought that the easiest way to get around this problem was to cast a concrete lintel in situ. Is this a good idea?
I had intended to put a few reinforcing rods in place just for good measure, but any other hints or tips would be most welcome. The lintel does not have to support much as there is a steel lintel holding the external wall, and there is a door directly above this opening along with its own steell lintel
Thanks in advance
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 29 times
PostPosted: Sun Feb 15, 2004 4:31 pm    Post Subject:
Concrete lintel would be better but make sure the supports are in the right place before removing old lintel.You can get lighter strong metal lintel depending on your stress load.
Back to top
 Alert Moderators
Antwerpman
from Belgium
Thanked: 0 times
PostPosted: Sun Feb 15, 2004 5:35 pm    Post Subject:
too late, the old lintel had rotted away and fell apart in my hands. Like I said there is not really much above it (a door with its own lintel) so I dont think it is suporting much.
Is there anything I should watch out for when casting the new one??
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 29 times
PostPosted: Sun Feb 15, 2004 8:23 pm    Post Subject:
Make sure the concrete a good ratio mix and do it asap.
Back to top
 Alert Moderators
Antwerpman
from Belgium
Thanked: 0 times
PostPosted: Sun Feb 15, 2004 9:56 pm    Post Subject:
I was just planning on using a couple of bags of ready mix, will this be ok??
what do you define as a good mix ratio?? (the stuff I bought was for foundations)
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Casting a concrete padstone in situ 5 5180 Wed Aug 02, 2006 11:28 am
Casting Lintels in situ 6 540 Sun Apr 19, 2009 3:30 pm
casting semi-decorative concrete bath base 5 360 Fri Feb 06, 2009 2:45 pm
Casting my own concrete bricks/blocks 5 600 Tue May 24, 2005 7:16 am
how to make lintel safe??? 5 460 Tue Nov 24, 2009 5:14 pm
DIYnot
