aspruce
Joined: 25 Oct 2006 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Wed Oct 25, 2006 10:00 am Post Subject: 1 gang 2 way but 5 wires |
I\\\'ve been reading the posts here and it seems 2 way switches are usually used when there are more than one switch controlling the same light/set of lights.
I have a dressing room that has only one set of halogen lights. When I pull off the face plate there are 5 wires 2 black going in N1 and N2, 2 red going into L1 and L2 and an earth.
I\\\'m trying to replace with 1 of 2 switches I have. One is a dimmer but has no earth connection. The other is a 1 gang 2 way with L1 L2 and Common inputs.
Any idea why there are so many wires for a room with one set of lights? What is the correct configuration?
TIA. |
Spark123
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Wed Oct 25, 2006 3:57 pm Post Subject: |
It sounds like the original is a double pole switch, the blacks being the neutrals and the reds being the lives. Is it fed from the lighting circuit? Are the halogens mains or 12v? How many watts of lighting and what size dimmer switch? |
aspruce
Posted: Wed Oct 25, 2006 4:16 pm Post Subject: |
Quick reply. Didn't expect that.
It is fed from the lighting circuit and they are mains fed. There are 6 50W halogens. The dimmer looks like a one way switch with 2 inputs the other swith I have is a one gand 2 way with L1 L2 and common |
Spark123
Posted: Wed Oct 25, 2006 5:14 pm Post Subject: |
You'll need a minimum 600w dimmer or one that is already de-rated for halogen loads.
Other than that, see: wiki, (just ignore the supply to next light cable) |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Wed Oct 25, 2006 6:00 pm Post Subject: |
does the existing switch have a fuse?
i am thinking it my be an fcu, fed from ring __________________ Do you like music Mr Finch?
Forum = Opinions |
aspruce
Posted: Wed Oct 25, 2006 7:03 pm Post Subject: |
No fuse. |
securespark
Joined: 11 Jan 2004 Posts: 16480 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Wed Oct 25, 2006 9:41 pm Post Subject: |
Does the switch say "DP" or "double pole" on the back? What rating is it? __________________ As George Michael once said, "..if you're gonna do it, do it right, right?" |
