DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fitting Towel Warmer - Mistral Valve
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Fat Lady
from United Kingdom
PostPosted: Wed Oct 25, 2006 10:27 am Reply with quote
I have a microbore system which uses a 2 pipe system with the mistral valves, so just one entry point to radiator. I would like to fit a towel warmer in the bathroom but as all that I can find have the pipe entries at the bottom, I need an elbow to connect to my mistral valve. All radiator tail connectors seem to be straight.
Anybody got any idea if there is such a connector or what arrangement I could use to avoid having to connect new pipes etc as the floor is solid concrete and so would involve lots of dirty drilling. Also don't fancy just bringing the microbore along the wall under the towel warmer as that would look cluttered and also prone to getting damaged.
Andrew
Back to top
 Alert Moderators
HarrogateGas
from United Kingdom
Thanked: 8 times
PostPosted: Wed Oct 25, 2006 10:58 am Reply with quote
wy not just cut the pipes to the twin entry valve and run it as a standard towel radiator with two straight rad valves?
Back to top
 Alert Moderators
Fat Lady
from United Kingdom
PostPosted: Wed Oct 25, 2006 11:03 am Reply with quote
Thanks for your reply, the twin entry valve is located such that I can not mount the towel radiator in the middle because the radiator would then be partly behind the toilet bowl. I wanted to avoid running a pipe along the wall if possible as it is likely just to get knocked with the hoover etc.
Andrew
Back to top
 Alert Moderators
HarrogateGas
from United Kingdom
Thanked: 8 times
PostPosted: Wed Oct 25, 2006 11:06 am Reply with quote
run the pipwork under the floor?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3428 times
PostPosted: Wed Oct 25, 2006 11:20 am Reply with quote
All the twin entry microbore valves have a tube which goes into the rad from the valve.
You could make an elbow arrangement but that would require a very flexible inner tube and yours may not be very flexible and will probably flatten.
I dont understand why you are unable to extend the microbore pipe to each side of the towel rad.
Tony
Back to top
 Alert Moderators
Fat Lady
from United Kingdom
PostPosted: Wed Oct 25, 2006 12:42 pm Reply with quote
Thanks for your replies, a trip to B&Q and a play about with a few bits and pieces has led me to the following solution which will provide a nice neat finish and no need for trailing microbore which will just get damaged.
I will leave the existing radiator tail connected to valve then connect a 1/2'' female BSP to 15mm commpression elbow, like the one below
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100122&ts=79729&id=17647
Then I will use a commpression radiator valve tail to connect that to the towel radiator.
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=15531&ts=79983
Job done, 4.00 or so and not too untidy.
The injector tube is plenty flexible and will easily go around the bend with no flattening.
Andrew
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3428 times
PostPosted: Wed Oct 25, 2006 12:49 pm Reply with quote
If its that flexible then it should be on the flow and definately not on the return otherwise it will be flattenned by the flow!
Tony
Back to top
 Alert Moderators
Fat Lady
from United Kingdom
PostPosted: Wed Oct 25, 2006 12:56 pm Reply with quote
Hi Agile,
It is on the flow, see the following picture about half way down the page for the type of tube I am talking about.
http://www.yorkshirefittings.co.uk/fittings.cfm?brand=07&defsub=40
Maybe we are not talking about the same thing, but the flexible pipe which extends the flow out of the valve and into the radiator is made of much stronger stuff than the microbore pipe itself. It is sort of corrugated to allow it to bend to insert it into the radiator.
Andrew
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Leaky Mistral TRV 2 300 Thu Dec 10, 2009 10:34 am
Mistral Oil Combi High Limit Stat Tripping 6 260 Mon Oct 25, 2010 4:37 pm
Help!! Need to re-start mistral boiler!! 10 100 Fri Jan 06, 2012 4:40 pm
Mistral Oil Combi Leaking 4 60 Thu Feb 02, 2012 3:02 pm
Mistral Combi boiler making steam engine noises! 4 400 Sat Apr 11, 2009 8:15 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
