RHF
Joined: 25 Oct 2006 Posts: 2 Location: Berkshire, United Kingdom Thanked: 0 times
ollski
Joined: 08 Oct 2003 Posts: 4493 Location: Birmingham, United Kingdom Thanked: 10 times
RHF
Posted: Wed Oct 25, 2006 12:32 pm Post Subject: |
Ah, ok, anyway, its a boiler in the kitchen that does hot water and heating, assumed it was a combi boiler but maybe that's something all together different.
So, will draining the system damage the immersion tank or cause me to bleed the radiators? |
holty
Joined: 14 Jan 2006 Posts: 1343 Location: Cornwall, United Kingdom Thanked: 21 times
Posted: Wed Oct 25, 2006 6:42 pm Post Subject: |
1: if you have a combi yes turning the cold supply off will shut off both hot and cold but make sure the boilers off
2:if you do have a cold water tank feeding the hot water cylinder in the loft and a smaller seperate tank for boiler then yes cutting the supply to the cold water tank, feeding the cylinder will stop hot water flowing till the tanks drained.this will not effect any emmersion heater unless you drain the hot water cylinder wich you will not need to do.nor bleeding rads cos its a totally seperate circuit to the ch.hope this helps |
gigz
Joined: 07 Oct 2006 Posts: 590 Location: United Kingdom Thanked: 4 times
Posted: Wed Oct 25, 2006 6:45 pm Post Subject: |
He could have a combi with top up tank |
holty
Posted: Wed Oct 25, 2006 6:49 pm Post Subject: |
true. but till the poster gives us all some clues we could be guessing forever |
