DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
ELECTRIC FULLY TRIPPING OUT - please help!
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
cashka76
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 26, 2006 11:18 am    Post Subject:
Reply with quote Thanks
Hope you can help. Our Hager consumer unit is tripping out intermittently (maybe about once a day). It is the MAIN switch that goes, not just one of the individual fuses, so we are really stumped as to where the problem could be. I have noticed over the last week that it tends to happen at about 6.30 in the morning!!! Is it possible that there is some kind of incoming surge in power at that time that results in the whole thing blowing?
Hope you can help shed some light!
Claire
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Inky Pete
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 26, 2006 11:27 am    Post Subject:
The problem's going to be something internal to the house, not any kind of incoming surge.
What time does your heating come on in the morning?
Back to top
 Alert Moderators
slippyr4
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 26, 2006 4:18 pm    Post Subject:
is your "main switch" actually an RCD? with a test button, and something like 60A/30mA written on it?
A isolator switch will not turn itself off unless you have poltergeists.
Back to top
 Alert Moderators
industryspark
from United Kingdom
Thanked: 1 time
PostPosted: Thu Oct 26, 2006 4:49 pm    Post Subject:
im thinking the post is reffering to an RCD.
if it happens consistently at the same time then the fault should be easy to find.
once you think you know the offending circuit, you could leave that circuit off for a few days running to see if that is indeed the problem.
__________________
remember......a little bit of knowledge is often more dangerous than no knowledge at all!
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Thu Oct 26, 2006 6:32 pm    Post Subject:
Definitely an RCD. What sort of earth system do you have? Unless its TT, with an earth rod, theres no need for the mainswitch to be an RCD (and it shouldn't be, for the reason you've highlighted in your post - all the electric goes off it theres a fault). An electrician could alter this setup for you. I reckon your heating is set to come on at 6:30 icon_wink.gif
Back to top
 Alert Moderators
Markir
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 03, 2006 8:01 pm    Post Subject:
Also experiencing this problem
_____________________________
lynda, moderator
please note forum rule 20
Back to top
 Alert Moderators
chrisbyrd
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 03, 2006 8:04 pm    Post Subject:
does anything else come on at 6.30? anyone getting up early for a shower?
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 03, 2006 8:40 pm    Post Subject:
Re: ELECTRIC FULLY TRIPPING OUT - please help!
Claire
Claire, check the timer settings for your heating system or water heating system (Immersion), whichever you have. It could be that one of the parts of this system has developed a fault and is causing the trip.
Also, what time do you and your partner rise in the morning? Is there something about your routine that could shed some light on the matter? Do you have an electric or power shower that is invariably used at about 06:30?
Have a good think, it is likely to be something simple to identify when you check everything.
__________________
I only do commercial and Industrial so Prescott can shove his Part P tax
Back to top
 Alert Moderators
Invisible-Man
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 03, 2006 9:25 pm    Post Subject:
Am I right in thinking that if you were to detect the circuit of the fault (so happens to be a neutral/earth fault), then isolate via keeping mcb switched off on that circuit the fault would still trip a RCD !!!
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sun Dec 03, 2006 9:34 pm    Post Subject:
If it's an N/E fault, yes. If an L/E fault, it is possible to isolate it by switching mcb off.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Sun Dec 03, 2006 9:36 pm    Post Subject:
Neutral/earth fault can trip RCD with its Phase conductor isolated - it depends if there are any other circuits drawing current giving rise to imbalance in the RCD because of their neutral current leaking to earth via the fault
Back to top
 Alert Moderators
Invisible-Man
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 03, 2006 9:47 pm    Post Subject:
The point I was getting to, is that to completely isolate a found fault (neutral/earth) not knowing the reason for it and not a plugged in item, you would have to say in a immersion heater physically un-wire the heater to stop the RCD from tripping rather than switching the MCB off, maybe a difficult task for a DIY'er, and could make tracking down a fault a bit more difficult than just isolating a circuit by switching MCB's off one by one, thus throwing a DIY'er off the scent as it were
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sun Dec 03, 2006 11:56 pm    Post Subject:
An immersion heater is very likely to have a local DP switch for isolation. So are other fixed appliances like cookers. Non-fixed appliances will have a plug you can pull out.
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 04, 2006 12:11 am    Post Subject:
Invisible, John is right, and as far as I am aware, to comply with Britich Standards, FCU's need to be Double Pole switched anyway, so it is likely that you would isolate the fault by turning off the offending equipment..
Could be wrong on the DP requirement for the FCU's though..anyone know the exact position on this?
__________________
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Dec 04, 2006 1:55 am    Post Subject:
As far as I remember, there is no requirement to switch the neutral, but a DP switch is considered good practice.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
advice re changing room stat on honeywell fully pumped syste 4 480 Wed Mar 19, 2008 12:17 pm
Lights not fully off when off ?? 7 580 Wed Nov 24, 2004 10:45 am
Practical demo of fully coiled extension lead 7 740 Fri Dec 23, 2005 9:31 pm
PLZ HELP ELECTRIC TRIPPING OUT 30 4880 Tue Jun 13, 2006 6:32 pm
ELECTRIC SHOWER TRIPPING 9 3240 Fri Sep 22, 2006 10:05 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
