MAYTAG - QUIET SERIES 100 - no water????
27 Oct 2006
My dishwasher was working correctly and the next day it did not want to fill up with water. I have checked the water supply and the inlet. I looked inside the inlet and it does not have anything blocking it. Any suggestions?
That's Odd. I was just searching for the exact same problem? My Maytag Quiet Series 100 also has no water. And, I also have checked all the water connections. Any thoughts?
I found the source of my problem. Somehow my wife had pulled out the floater and did not put it back the right way. The floater has a sensor or a relay that activates the water inlet valve. Check if that is your problem. You can also check the valve itself to see if you have anything blocking the valve inlet. you can e-mail me as I was able to get some assitance from a friend.
_________________________________
Lynda, moderator.
Your email address is not in your profile, no one can email you.
Please also seee forum rule 7
