DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
boarding the loft
This topic originated from the How to page called Loft Insulation
Click here to return to the page called Loft Insulation.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
valandian
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 28, 2006 3:06 pm    Post Subject:
boarding the loft
Reply with quote Thanks
I'm after a bit of advice regarding loft insulation.
unfortunately & stupidly I have started boarding the loft out without laying insulation down first. I even considered it at the time and decided against it for budget and labour reasons (I'm not much of a DIYer) which makes my decision even more stupid, I know.
I have now decided to pull the boards up and put the insulation down before I go any further with the boarding.
My joists are 150mmm deep and I'm thinking of using Space Blanket but which should I use for the best efficiency? 200mm thick and compress it or the 150mm thick?
The recommendation is 270mm but I really do not wish to packout the joists to give me the extra depth, is this another stupid decision?
Also the gaps between my joists range from 280mm to 410mm, the blanket having a width of 370mm, will the short fall be a problem?
If anyone can help me please do.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Oct 28, 2006 3:41 pm    Post Subject:
My joists are 150mm deep and I'm thinking of using Space Blanket but which should I use for the best efficiency? 200mm thick and compress it or the 150mm thick?
If you only have a 150mm space then there is no point in trying to fit in more than 150mm of insulation.
It is more work, but counterbattening will allow more insulation as well as making the floor more rigid and spreading the weight. I assume you are not making it into a habitable room or putting anything heavy up there, which will require reinforcement? Just storing the Xmas decs and your Judy Garland record collection?
Yes. You must cover the ceiling completely. You can cut the insulation to fit. Make it slightly wider than the gap so it squeezes in well without gaps. You can do this with big paperhangers scissors or a breadknife after unrolling, but it is quicker to cut the complete pack with a fine saw or very big knife like slicing a swiss roll.
Back to top
 Alert Moderators
valandian
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 28, 2006 7:01 pm    Post Subject:
Thanks,
Yes I am only going to be using it as storage but some things are more middle weight than light weight, I have a vast catolouge of Julie Garland LPs.
No seriusly though, I will be storing things like old prams, TV sets and such up there if it is safe to do so.
Back onto the insulation, my other idea was to insulate between or even over the rafters of the roof, this way I could put up a full 200 or so mm if I had some way of fixing it up there, maybe stapleing or nail gun.
Does this sound like a good plan ?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Oct 28, 2006 7:07 pm    Post Subject:
You can do that if it is felted and in good condition (watertight, not too aged). You have to allow for good insulation of the roof timbers. Look at aluminised bubble-wrap type stuff to staple up. You will probably tear it if you are clumsy up there. The fibreglass above the first floor ceiling is I think your top priority.
Do some searches or browse the lofts section, there is lots of info already.
Back to top
 Alert Moderators
valandian
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 28, 2006 11:21 pm    Post Subject:
it is felted and there is absolutly no sign of damp up there!
Is there a risk of condensation? I was told there could be!
I saw the bubble wrap stuff today and, immediatly thought "that is the way to go!"
If this stuff can be as effective as the (rock wool/ space blanket) then I'm all for it, but I was told that it is better to do the floor!
Basicly I'm after effectivness verses cost!
And in the long run is it better to do the floor ?
Thanks for your help, I do appreciate it!
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Sun Oct 29, 2006 12:28 pm    Post Subject:
If you do the ceiling insulation and roof rafters insulation together then the risks of condensation will be a problem, so it's one or the other and not both.
Use something like 3"x1" timber flat in opposite direction of the ceiling joists in line with the T&G boards joints for support as this will give you a cross air-flow and no need to cut out section for the pipe/cable of the ceiling joists which will weaken the joists.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
Reg_Prescott
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 05, 2006 5:43 pm    Post Subject:
Im in a similar position, I need to board my loft for storage, but my existing insulation is somewhat lacking. Anyhoo, I have stumbled on a product by "Knauf" called polyfoam supadeck. Is is basically loft boards with integral insulation. Good luck trying to get hold of it though, they only seem to sell to the trade icon_confused.gif They also do a product which is designed to go *over* loft boards. I have seen this in B&Q. I;m still checking it out, but it may be worth a look...
Good luck!
__________________
Here we have our old friend, the circular saw - AARRGGHH!!!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Boarding a loft over very thick insulation - Problems? 2 2240 Tue Feb 19, 2008 7:11 pm
Being a bit thick about boarding the loft. 2 1400 Tue Jan 29, 2008 7:44 am
Loft Insulation / boarding - not such a simple science 8 5100 Wed Apr 23, 2008 11:42 am
Boarding my loft/ insulation dilemma 4 1400 Thu Jun 26, 2008 12:51 pm
Loft Boarding with Insulation 5 1240 Fri Aug 29, 2008 5:23 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
