control panel fault or piping problem ??
29 Oct 2006
Devon
Moved into our house back in July and just switched on the heating to see if it all works ok, all the rads heating up fine, so I left the rads switched on on their individual valve thermostats, and turned the heating off on the boiler control panel (Danfoss FP715), when the boiler came on the following morning to heat the water the rads also heated up, although the heating was switched off on the boiler control panel. Anybody any idea as to whats going on and is it easy to sort out.
If you have two motor valves the CH one may be faulty or locked on in the manual setting.
If you have a single three port valve then it may be faulty or seized up or on some models locked in a manual central mode.
Tony
Hi Tony,
Thanks for the quick reply, I have a white box which says type HSA3 on it, there is a switch that says auto /manual, it is switched to auto at the moment. is this where the problem lies do you think ?
regards.
Paul
