Will it fit in the space?
29 Oct 2006
I've just moved in to a new home, and my kitchen has space for a dishwasher. However, the depth is exactly 60cm, and there is a pipe present at the back running across the space. I understand dishwashers have a depth of 60cm, but would the recess for inlet/waste papes also allow the machine to sit in front of this pipe? It sits about 8cm out from the back wall. There is also a plug socket behind there, so this would need to sit comfortably behind the machine too.
Many thanks in advance.
Andy
If it's a waste pipe and it's more than a couple of inches from the floor then you'll have problems.
Same with the socket, the plug will be pushed into the rear of the dishwasher but you could always change the socket for a fused, switched outlet.
