DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Painting on uneven walls
This topic originated from the How to page called Preparing Walls and Ceilings
Click here to return to the page called Preparing Walls and Ceilings.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Bling
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 30, 2006 1:14 pm    Post Subject:
Reply with quote Thanks
Help - we have just bought a 1975 house - we have stripped all of the wallpaper off, and underneath the walls seem fairly smooth - with the exception of a bit of yellow paint a few minor imperfections - How can I get these walls smooth without skimming? icon_question.gif
I like painted walls, so do I need to spend hours sanding down each wall? or is there a quick fix way (I know its a stab in the dark! icon_lol.gif )
If I have to skim what sort of approx cost for 20' x 20' room?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Zampa
from United Kingdom
Thanked: 3 times
PostPosted: Mon Oct 30, 2006 5:13 pm    Post Subject:
Fill the walls...sand down and line em with 800/1000 grade lining paper.
__________________
How much!
Back to top
 Alert Moderators
Bling
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 31, 2006 11:02 am    Post Subject:
Thanks will get on with it at the weekend!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Oct 31, 2006 11:21 am    Post Subject:
I find I get better results if I:
Use Finish plaster (not polyfilla) mixed fairly thin... like a thick custard. Just a bit of it in a margarine tub or something (this is assuming you're just perfecting the surface, not filling holes and chases which is a different thing).
Apply it with a broad filling knife (like, 100mm wide)
Apply hardly any, and use the knife to press it flat (no bulges that you will have to take off later)
After it's dry, scrape off any lines with a broad scraper (not sandpaper).
I give them a coat of thinned white matt emulsion when I think they're flat and smooth; that evens up the colour and suction and makes it easy to spot any defects so I can correct then before applying the colour. It also provides opacity to hide old colour mismatches or patterns on the wall.
(I am just a clumsy amateur)
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Very uneven walls 2 8200 Fri Jul 08, 2005 7:45 am
best solution for long hall with uneven walls? 9 1060 Fri Dec 28, 2007 12:51 pm
Uneven walls 6 780 Mon May 07, 2007 8:22 am
Smoothing uneven ceilings 7 5500 Thu Jun 01, 2006 11:34 am
Uneven skimming 5 780 Tue Nov 08, 2005 9:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
