DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replacing old 2 gang switch with new 2 gang dimmer
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
romecrane
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 31, 2006 2:28 pm    Post Subject:
Reply with quote Thanks
New switch has common plus L1 & L2 on each switch. Old (non dimmer) has red on common and black on 2 on one light. Other switch has red on 2 with black on 3 and common connected to other common. Note this is just a one way switch with each switch controlling one light. How do I connect up this old wiring to new switch?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue Oct 31, 2006 5:41 pm    Post Subject:
Firstly, be aware of the split of the terminals on the old switch, and which terminals are for which switch, it can sometimes look confusing and catches many DIYers out.
2 = L1
3 = L2
Back to top
 Alert Moderators
romecrane
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 31, 2006 5:58 pm    Post Subject:
Thanks. What I don't understand is why red is on 2 & black on 3 on one old switch with common linked? Other switch is red on common with black on 2.
Back to top
 Alert Moderators
chaza
from United Kingdom
Thanked: 0 times
PostPosted: Wed Dec 20, 2006 9:00 am    Post Subject:
2 WAY SWITCH
I HAVE MOVED INTO A HOUSE AND THERE IS NO SWITCH PLATES, UPSTAIRS HAS ONE CABLE, RED BLACK & EARTH.
DOWNSTAIRS HAS TWO CABLES ONE GOING UPSTAIRS AND ONE WHICH I THINK IS THE SUPPLY. CAN YOU TELL ME HOW TO WIRE THEM UP, I AM UNSURE OF THE PATH THE CURRENT TRAVELS TO DO THE JOB.
WOULD I BE RIGHT IN SAYING,
UPSTAIRS RED & BLACK GO IN THE EACH POINT ON THE PLATE, IT DOESNT MATTER WHICH ONE.
DOWNSTAIRS BLACK FROM UPSTAIRS GOES INTO COMMON ON THE DOWNSTAIRS PLATE, TWO REDS GO INTO L1( WHICH WILL BE RED FROM UPSTAIRS AND RED FROM SUPPLY) AND SUPPLY BLACK GOES INTO L2.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Wed Dec 20, 2006 11:32 am    Post Subject:
Please turn CAPS LOCK OFF!! Also, replying to old posts sets off the big siren at Mod HQ and they will be along in a minute to slap your wrists icon_biggrin.gif .
I don't really follow what you think you have, is it a light switch at the top of the stairs and one at the bottom? There doesn't sound to be enough cables for a normal 2way setup, would they have been push timers or something similar? Or are you talking of different lights?
Back to top
 Alert Moderators
chaza
from United Kingdom
Thanked: 0 times
PostPosted: Wed Dec 20, 2006 3:34 pm    Post Subject:
as far as i know there should be a yellow wire but there are only red and black it worked before so there has to be a combination to the wires if you can help please.
thank you
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Replacing a 2 gang 1 way switch with a dimmer 3 420 Mon Oct 27, 2003 1:14 pm
Replacing 2 Gang Switch with 2 Gang Dimmer SWITCH 4 580 Sun Nov 02, 2003 1:06 pm
Replacing 2-Gang Switch with Metal Dimmer 2 2280 Sun Sep 16, 2007 9:51 am
Replacing a 2 gang dimmer switch 2 2820 Sat Mar 13, 2004 5:33 pm
Replacing a 2 gang dimmer switch 4 2420 Thu Apr 07, 2005 11:15 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
