DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
adding a fused spur / RCD for underfloor heating
This topic originated from the How to page called Adding a spur to a ring circuit from a socket
Click here to return to the page called Adding a spur to a ring circuit from a socket.
  View previous topic :: View next topic
Author Message
mjoshyuk
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 31, 2006 6:55 pm    Post Subject:
Reply with quote Thanks
Im fitting electric underfloor heating to my small extension, 2m2. The instructions say that a RCD should be installed. Next door to this new extension i have a existing fused spur that is no longer used located in a bathroom (toilet and basin only). Am i able to install the RCD in the bathroom and run cable to thermostat located in the new extension or or does this require a junction box instead of existing fused spur and the RCD located in the new room next to thermostat
thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
sparky40
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 31, 2006 8:36 pm    Post Subject:
Hello,
Could you not 'in line' crimp the cables in the existing spur, and take the feed through the wall into another spur, and blank plate over the existing ?
Hope that this is of some help.
Back to top
 Alert Moderators
mjoshyuk
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 31, 2006 8:56 pm    Post Subject:
Hi
Thanks for the reply
Would the in line crimp be OK,
The plan is to install cabling, RCD and thermostat and leave for sparky to connect and test.
thanks
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Tue Oct 31, 2006 9:10 pm    Post Subject:
It would be better with an RCD FSU next to the thermostat for isolation purposes. It is probably a good idea to have a spark who is a member of a competent person scheme oversee this as underfloor heating is a special installation and hence notifiable under part p of the building regs (England / Wales).
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Tue Oct 31, 2006 11:15 pm    Post Subject:
If the place where teh existing FCU is located only has a basin and toilet then it is not classed as a "bathroom".
You could just swap the existing FCU for an RCD spur. Unless the circuit is already protected by an RCD (at the fuseboard eg).
But per Spark123's post. This work is notifiable so its better to get a resgistered spark in and let him worry about evrything for you...
TTC
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Nov 01, 2006 12:35 am    Post Subject:
I'll go with that. Fit an RCD spur in place of existing in the loo, drill through and run the feed to the control box, then from there you will run the probe and element flexes down to the floor. Is it WarmUp?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
mjoshyuk
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 01, 2006 8:11 pm    Post Subject:
Hi
Thanks for the advice
Sparkys are like hens teeth around here,
Yes it is Warm-up
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Spur and underfloor heating of ring. 7 400 Sun Aug 17, 2008 10:29 am
Recommended Electric Underfloor Heating System 11 540 Thu May 08, 2008 12:00 pm
ELECTRIC UNDERFLOOR HEATING CONNECTED TO THE FUSE BOARD 8 460 Sun Mar 30, 2008 9:45 pm
Underfloor heating calculations 3 280 Wed Mar 05, 2008 11:33 pm
underfloor heating 6 240 Tue May 27, 2008 12:15 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
