Just looking for some advice... I had a plumber fit a new bathroom suite in my flat recently and he broke off the entire cast iron branch/tee that connected the bath to the shared waste stack (also cast iron). Skipping the argument of whether, in his words, it just came off in his hands or whether he was being a bit ambitious with a hammer, he 'fixed' it by running a smaller diameter PVC pipe into the hole in the stack where the branch once was, and filled around the (irregularly shaped) hole in the stack with silicone sealant. That was a couple of months ago, but just this weekend my downstairs neighbour woke me from my slumber to tell me her ceiling was wet and a wall was soaked enough to cause tiles to come off in her hands. I went down to have a look and, as I believe is typical for these type of tenement flats, the shared stack is hidden away in a boxed area that runs vertically inside each flat, so we managed to saw into the box and see water running down the outside of the stack from ceiling level, so it was almost certainly coming from my property. To cut a rambling story short, it turns out that a hole had developed in the silicone which is where the leak was coming from. I had an independent plumber come out and look at it and his opinion was that using sealer in these circumstances was definitely not recommended and that to fix it properly would be to replace the piece of main stack, a not inconsiderable (or inexpensive) job from what he said.
The original plumber has since been back out, and has applied more silicone sealer over the top of the old stuff and 'guarantees' that it'll hold this time. I'm obviously nervous that the neighbour is going to get her bathroom repaired only for this to all happen again in a month or six. Is silicone sealer an acceptable/reliable solution to this problem, or is there some sort of collar type of thing (like a strap boss, but tall enough to patch the 200mm or so hole in the stack) that would be more effective than sealant, or should the section of stack be replaced as advised by the independent plumber?
Advice, comments and observations gratefully received!
