Just purchased a new cooker and had a good read through here for an answer, but found nothing definite. My existing cooker simply plugs into the ring main as its loading is only 2.2Kw. The new cooker states its 3.7Kw-16amps. I read through the Beaumatic blurb but could not find if this was total load or if some elements can only be used without others. I have a dedicated ring main to the kitchen with 4 double sockets and I single for the dishwasher. Can I connect this cooker to this circuit by changing the socket to a dp switch? Hope you can advise. Thanks.
Oven
Temperature selector / Oven function mode
selector 1/1
Baking levels
- telescopis guides at 3 levels (certain
models only)
5
Upper /lower heater (kW) 0,9/1,1
Infrared heater/ Infrared heater
with fan (kW)
2,0/2,2
Oven illumination top/side (W) 25/25
Modes of operation
Upper /lower heater (kW) 2,0
Grill heater (kW) 2,0
Grill with fan (kW) 2,0
Hot air / lower heater (kW) 3,4
Hot air (kW) 2,2
Defrost (W) 50
Lower heater / fan (kW) 1,1
Lower heater (kW) 1,1
Max. temperature 275 °C
Mains voltage 400 V 2N~, 50 Hz
Heater voltage 230 V, 50 Hz
Total mains power (kW) 5,4
Oven total (kW) 3,4
Hotplates total (kW) -
Burners total (kW) 7,8
Total mains power (g/h) 567
Oven
selector 1/1
Baking levels
models only)
5
with fan (kW)
2,0/2,2
Modes of operation
Hot air (kW) 2,2
Defrost (W) 50
Oven total (kW) 3,4
