sharonfla
Joined: 04 Nov 2006 Posts: 3 Location: United States of America Thanked: 0 times
Zampa
Joined: 14 Mar 2005 Posts: 5727 Location: United Kingdom Thanked: 3 times
Posted: Sat Nov 04, 2006 7:00 pm Post Subject: |
Not easy Shaz...im not that familiar with the paint products in the U.S but im sure youl have Zinseer 123 bulleye over there...they do a massive range of paints for problem surfaces.
Check out your local Lowes or Home store..
And order me a nice big sub in publix while your at it...im coming out in October and cant wait to plunder the DIY shops you have out there. __________________ How much! |
sharonfla
Posted: Sat Nov 04, 2006 8:01 pm Post Subject: |
NOT ONE PERSON AT HOME DEEPOT KNEW THE ANSWER TO MY QUESTION. WHY DO YOU THINK I'M ASKING YOU GUYS....HELP |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Sat Nov 04, 2006 8:05 pm Post Subject: |
This is a UK site so we aren't familiar with the paints and merchants in your country.
BTW, please turn off your
Zampa
Posted: Sun Nov 05, 2006 10:08 am Post Subject: |
Can you wait until next October Sharon?...i'll bring the stuff and do it myself!
You should give them a good rub down/abrade with wet or dry paper first..fine grade (400 or thereabouts)
Then get yourself a can of Zinseer B.I.N primer/sealer for the first coat.
http://www.zinsser.com/product_detail.asp?ProductID=10
Apply it with a foam radiator roller to eliminate the brush marks and give you a uniform even finish..
Allow to dry and apply another coat, before you put the finish coat on ...give the surface a rub over with the fine wet or dry paper to remove any airborne surface nibs.
(i would go for a semi gloss, or 'sem-i as you say..  finish __________________ How much! |
sharonfla
Posted: Sun Nov 05, 2006 7:55 pm Post Subject: |
ZAMPA......THANKS FOR YOUR OFFER BUT I'LL GO CRAZY BY THEN...I WILL TRY TO ORDER THE PRODUCT ONLINE THAT YOU SUGGESTED. THANK YOU FOR YOUR INFO AND TIME...SHARON |
