DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
3 Gang 2 Way 10 Amp light Switch
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
dj icea
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 04, 2006 8:21 pm    Post Subject:
Reply with quote Thanks
i have just brought a 3 Gang 2 Way 10 Amp light Switch as i need to turn on 3 lights which has 1 main power coming into it how can i do this please i need to no as soon as possible. thanks in advance. i don't under stand all this com,l1,l2 on the back of the plate if some one could tell me what they stand for please
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat Nov 04, 2006 8:38 pm    Post Subject:
What do you have coming to the switch, a L,N & E feed? C is the common terminal. L1 is way 1 and L2 is way 2, there will be a C, L1 and L2 for each switch, the switch will be switching together C - L1 with the switch in one position and C - L2 with it in the other.
Back to top
 Alert Moderators
dj icea
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 04, 2006 8:46 pm    Post Subject:
i have 3 lights coming in does the c mean earth? L1 live L2 neutral?
that what i dnt get where to put the wires
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat Nov 04, 2006 9:00 pm    Post Subject:
No, Com, L1 and L2 are all live terminals. L2 may not be needed for single way switching so needs to be left empty for now. Neutral and earth need to be connected into terminal block, an earth loop to the switch and back box if metal too. Live in goes to one common and loops to the other two commons. The three (switched) live wires to the lights can go into each of the L1 terminals.
Back to top
 Alert Moderators
dj icea
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 04, 2006 9:17 pm    Post Subject:
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Nov 04, 2006 9:49 pm    Post Subject:
dj icea wrote:
[img=http://img248.imageshack.us/img248/7135/wiresji5.th.png]
is that right?
Back to top
 Alert Moderators
dj icea
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 04, 2006 9:55 pm    Post Subject:
erm thats what i want 2 no how do i connect 3 lights to the 3 gang switch?
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Nov 04, 2006 9:56 pm    Post Subject:
FYI, NEUTRALS NEVER CONNECT TO A SWITCH! UNDERSTAND THIS BEFORE ANYTHING ELSE. IF YOU CANT, DONT ATTEMPT THIS WORK.
Are you wiring these lights from scratch??? Or do you have existing wiring??
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
Then what was the pic for?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Nov 04, 2006 11:59 pm    Post Subject:
dj icea, i am sorry to say but you do not appear to have the cometancy to grap the concept of how it should be done, as i would like to see you post on here again, i would suggest you call an electrician.
remember electricity has no prejudices, it kills anyone
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
dj icea
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 10, 2006 9:28 pm    Post Subject:
still dnt get you
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Nov 10, 2006 10:40 pm    Post Subject:
dj icea wrote:
still dnt get you
i shall put it bluntly then
you are too stupid to understand how to do it.
sorry but you did ask,(and its true)
As i would like to see you post again, please get an electrcian in to do the job
__________________
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
2 gang 2 light switch wiring help! 7 820 Tue Aug 09, 2005 1:55 pm
wiring a two gang light switch 2 660 Sun Jan 20, 2008 8:29 pm
Maximum load for three gang light switch 2 360 Fri Jan 25, 2008 12:27 pm
i need advise on wiring a ? 2 gang light switch 17 6840 Sat Jan 19, 2008 8:41 pm
Wiring a 2 Gang 2-way light switch for 2 lights 9 5000 Fri Aug 19, 2005 10:16 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
