amc1234
Joined: 05 Nov 2006 Posts: 1 Location: Ireland Thanked: 0 times
Posted: Sun Nov 05, 2006 2:37 pm Post Subject: Moving a socket |
I am moving a socket one foot higher up the wall, but there is not enough spare cable under the floorboards. How can I safely add more cable? There are two cables going into the socket. |
plugwash
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Sun Nov 05, 2006 3:54 pm Post Subject: |
why are you moving it?
easiest soloution (assuming the existing socket is on the ring) is to leave the existing socket where it is and run a spur to a new one. |
industryspark
Joined: 08 Jul 2006 Posts: 567 Location: Yorkshire, United Kingdom Thanked: 1 time
Posted: Sun Nov 05, 2006 6:10 pm Post Subject: |
or you could replace the cable legs that are too short (this could be a bit of hassle though)!!!
all depends on how good a job you want to do, plugwash's idea is a good suggestion but will you be happy with the look? suppose it depends on the location of the socket. __________________ remember......a little bit of knowledge is often more dangerous than no knowledge at all! |
