Bathroom quadrant tiles.
7 Nov 2006
Sussex
Hi peeps, my first DIYNot post:-
I have had to repair the tiled wall above the bath (stud wall/holds shower head). As a result I had to remove ALL the quadrant tiles from around the bath (two sides).
I am now ready to put them back but have a few queries that you may be able to help with:-
1. Use tile cement or silicone sealant to stick them on.
2. Does the cement/sealant get applied to the bat and wall before applying the quadrants OR does it get put onto the quadrant before sticking down (as with a normal tile)?
Thanks in advance for any replies.
Are you replacing the quadrants with new OR did you clean the old?
Use tile adhesive & grout..both need to be waterproof.
I'm using new quadrants.
Definitely use tile cement and not silcone caulk?
I used neutral curing silicone :oops: and pressed the quadrants into it .....but that was yonks ago
