Turn down the supply from the mains cold water via the stopcock, watch the temperature guage, it should increase as the less flow through the heat exchanger allows the water to absorb more heat from it. If this happens you need to remove the plate heat exchanger and either chemically descale it or replace with a shiny new one! On a 24 the hot water flow rate won`t be much to shout about anyway.
