DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Reconnecting Radiator
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
louise1015blue
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 09, 2006 12:47 pm    Post Subject:
Reply with quote Thanks
I am trying to reconnect a radiator - the nut from the radiator will not screw back on to the pipe connection. It tightens and then slackens appears the threads were damaged when the radiator was originally fitted. Can someone advise what I need to do without having to call a plumber if possible e.g. can I rethread the part on the pipe, I believe there is a tool that can do this?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Tom JE
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 09, 2006 1:14 pm    Post Subject:
I had the same trouble
You can unscrew that whole attachment from the radiator that the nut is on and replace it with a new one if need be. Or maybe try a few extra wraps of PTFE around the thread and see if the nut will be tight enough with that on - although i'm sure somebody here may correct me on that method.
Back to top
 Alert Moderators
louise1015blue
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 10, 2006 12:05 pm    Post Subject:
Hi
Thanks for the reply I will try the PTFE tape as have this. Not sure about the nut coming of the radiator, looks as if it is sealed to it?
Back to top
 Alert Moderators
louise1015blue
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 13, 2006 12:16 pm    Post Subject:
I now have leaks!
PTFE Tape worked the radiator is now reconnected, but I have slight leaks from both connections - how can I stop these?
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Mon Nov 13, 2006 12:28 pm    Post Subject:
If the threads are knacked then you will have to replace the valve or rad inserts. Won't cost you much, probably less than a £5 which will give you peace of mind.
If, however, the leaks are only slight then try a bit more ptfe tape. icon_biggrin.gif
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
louise1015blue
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 13, 2006 12:50 pm    Post Subject:
The radiators are brand new as a new heating system, radiators haven't been used til now, and i took them off to decorate.
The connection where the thermostat valve is leaking from connection closest to radiator. Other connection is leaking closest to pipe. If I attach more PTFE tape I will have to take everything off and drain radiator again?
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Mon Nov 13, 2006 12:57 pm    Post Subject:
louise1015blue wrote:
will "I have to take everything off and drain radiator again?
Fraid so. Make sure the pipe is not going in at an angle when you make the connection. icon_biggrin.gif
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Reconnecting WC to cast iron soil pipe - and plumbers hemp ? 2 1520 Wed Apr 13, 2005 4:39 pm
Disconnecting and reconnecting gas oven hob 4 180 Tue Mar 10, 2009 4:38 pm
reconnecting outside taps 5 200 Tue Mar 24, 2009 12:05 am
Reconnecting a push-fit connector 4 280 Sun Mar 16, 2008 2:48 pm
Fitting a towel radiator. 6 480 Tue Mar 11, 2008 8:33 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
