1Way Dimmer to a 1 way switch, weird black plastic box
9 Nov 2006
Hey, I am replacing a one way dimmer switch with a one way switch. (The dimmer doesn't work too well with energy saving light bulbs.) The wiring is not a problem for me as I have done it before. But I have never encountered a black plastic casing on the inside of the switch before. It covers all the wiring and screws on the inside. I tried to remove it but it seems stuck, and not knowing what it is am afraid to pull too hard. Anyone know what it is? I really do not want to call an electrician and spend $80 on a two minute job :( Plus it is really hard to do all this stuff in the dark LOL
on american dimmers there are normialy no screw connectors insted there are normaly two little wires comming out of the dimmer these wires are then connected using wire connectors to the house wiring
Is there any screw on connectors in the back of the box?
if there is disconect the cables from those connectors and reconnect your switch to the wires
low energy bulbs should not be dimmed with a dimmer
Nope the back of the switch is completely encased by this black plastic box. I think it might be a casing, like a dirt cover, but I am not sure :(
probably got some one in by now, nearly 2 months since it was posted
oops, this forum isnt as hot as the UK one, where I take it for granted that posts are recent
the little line of text above where you post is a give away, its called the date :LOL:
but to be honest I would not bother with electrics outside the UK as they
1) often post and go
2) not allowed to do anything anyway
3) do not understand what you mean
4) Differnt regs
5) diifernt kit
take this one its not no one wants to help its no one can help
and this forum is here to stop confusion from uk and non uk electrics
