Servis M6011 wont empty
9 Nov 2006
Liverpool
when machine is turned on it automaticaly fills, even on pump and spin, turns a few times then stops for a while, then repeats time and time again, it wont empty just goes back and forward, :please help: :
You can check and clean out your filter which will empty the machine if there is not too much water.
I think you have a problem with your control pcb which is an exspensive item & probably not worth repairing the machine, I'm not 100% sure. But in order to empty the machine in the short term, if you remove the drain hose from it's fixing at the back of the machine & lower it to floor level the machine will then empty under gravity & you can remove your clothes until you can get somebody to look at it. It will be easier if you can move the machine to an external door or drain that you can reach with the drain hose before you begin, so that the water will flow away.
