DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Turnign of the water in a converted flat
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Sharonie2
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 11, 2006 6:36 pm    Post Subject:
Reply with quote Thanks
I simply want to change a washer in my bath tap but when I turned the water mains off in the hall and ran the taps, the system does not seem to drain - it just keeps on coming at the same fantastic force!
The hot is off now as I turned a valve in the combi boiler but the cold keeps on coming!
Have I simply just not given it enough time or is there a chance that I'm draining the water from the flats upstairs too?
Should I just carry on running the cold tap - I dont know what else to do?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Paul Barker
from United Kingdom
Thanked: 19 times
PostPosted: Sat Nov 11, 2006 6:57 pm    Post Subject:
Each flat will have it's own stop tap you probably turned off someone elses water. Keep looking.
I assume it is the cold tap you have a problem with. If you are handy you could change the washer live if you run all other taps to reduce the pressure, then work at your leasure, while a little waterfall comes out over the body of the tap into the bath, no big deal.
So, run all taps, access washer, if you really care get friend to hold palm of hand over top hole so water goes usual route into bath while you change your washer.
We even do this with hot water sometimes, but we are used to getting burnt it's an occupational hazard.
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 19 times
PostPosted: Sat Nov 11, 2006 6:58 pm    Post Subject:
It's fun to hold the copper pipe you are soldering in your hand and see if you are still holding it as long as it takes for the joint to set, we usually start looking urgently for grips or a wet cloth all of a sudden.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Converted to combi now poor heating ?? 48 1900 Fri Apr 06, 2007 10:09 am
Help with Concord WRS 255 Converted to fully pumped system? 9 1620 Sun Dec 03, 2006 4:51 pm
Radiators in the converted loft are cold 6 3060 Wed Dec 13, 2006 6:31 pm
New hot water heating for 2 bed top floor flat 3 240 Fri Jul 20, 2007 11:53 am
Isolating flat with shared water supply 6 460 Thu Apr 06, 2006 3:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
