ianbellamy said:
I am fitting wall lights can I connect these to the ceiling light switch replacing the one way switch with a 2 way switch. There is only red, black, and earth in the switch box. I have channeled the wall ready to accept cable from the switch.
Ian, I think you are confusing One way and Two way switches with One Gang and two gang switches.
One Gang One way will be a single switch that can only switch one light or multiple lights.
Two Gang One Way will be a double switch that can switch two seperate lights or multiple lights
One Gang Two way is a single switch that is capable, with an identical switch and correct wiring, of switches a Light(s) from two seperate locations.
Two Gang Two can switch two seperate lights from two seperate locations using an identical switch or two seperate One Gang One way switches in seperate locations.
I think what you are talking about is using a TWO GANG switch in place of a ONE GANG, so that there will be TWO switches that operate the lights independantly...ie: One switch does the cieling light, one switch does the wall lights.
If this is correct then the answer is yes, but I must question your ability to safely and effectively do this as you are confused about the simple issue of switch nomenclature.
How do you intend to power these wall lights? Will you take the power from the Ring main via a fused spur, or from the lighting circuit?
If you intend to take power from the ring main via a fused spur, then you MUST NOT wire the wall lights back to the same switch as the cieling light, as these are on seperate circuits and you would be introducing a significant risk of shock to anyone working on the lighting circuit in future.
