DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electrical
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
  View previous topic :: View next topic
Author Message
wills
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 13, 2006 9:30 am    Post Subject:
Electrical
Reply with quote Thanks
I am embarking on a rewiring project.
Is there any benefit installing deep socket mounting boxes? I was going to use 25mm deep boxes but have noticed that 35mm and 47mm are available.
Any advice would be appreciated.
Thanks,
Wills
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Nov 13, 2006 9:33 am    Post Subject:
generally there is no reason to use 47mm boxes for sockets, they are mainly used for things like cooker control units where there are much bigger cables and terminals involved.
35mm boxes give a bit more wiring room than 25mm ones and make it possible to fit flat plate accessories if you wish later (very often theese simply will not fit on 25mm boxes)
Back to top
 Alert Moderators
Big_Spark
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 13, 2006 11:41 am    Post Subject:
Wills, are you aware of Part P and the legal requirements it entails?
Secondly, 25mm deep boxes are more than adequate unless you fit, as Plug said, the really flat plate faceplate..but these are generally cack.
Also you should determine how deep you can safely chase into your walls..25mm may be a simple task, but that extra 10mm may be difficult or you may end upin the cavity if the wall materials are weak..it is surprisingly easy to break through..
__________________
I only do commercial and Industrial so Prescott can shove his Part P tax
Back to top
 Alert Moderators
wills
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 13, 2006 4:45 pm    Post Subject:
Thanks guys.
Yes, Big Spark. I am aware of the Part P requirements.
Cheers,
Will
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Change in electrical circumstances 6 500 Thu Apr 03, 2008 4:39 pm
electrical points (switches, sockets) and the Hob distance. 3 840 Mon Mar 31, 2008 8:44 am
Result from Electrical visual survey 10 420 Mon Mar 17, 2008 8:53 pm
Electrical supply to Garage - Advice 13 2000 Fri Apr 18, 2008 1:22 pm
electrical installation work in hazardous environments 13 580 Sun Apr 27, 2008 12:11 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
