Joined: 22 May 2005 Posts: 21 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Mon Nov 13, 2006 5:28 pm Post Subject:
Faulty Bathroom Mirror Light
My bathroom mirror light seems to have broken!
Its a 240v, 60w, 284m, tube light.
I have tried replacing the buld twice. It started to flicker slightly several times before giving up totally. To turn the light on/off its a pull cord, not sure if this maybe the problem?
Joined: 15 Apr 2005 Posts: 12856 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Mon Nov 13, 2006 6:40 pm Post Subject:
is this a fitting with caps on the ends of the tube? or does it have caps on the sides? Either way, check there is physical resistance when you push the tube in/out.
Posted: Mon Nov 13, 2006 6:52 pm Post Subject:
Thanks for the replys.
Yeah it has caps on the sides, it can move left/right to allow you to remove the bulb. Not sure whether it should be pushed to one side or adjusted to the middle?
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Mon Nov 13, 2006 8:37 pm Post Subject:
Turn off the circuit and see if you can take the lamp apart. It may have a standard microswitch inside the moulded case. With luck the switch will have makers name and part no on it (if not photograph and measure it) and someone here may know where to get a replacement.
Posted: Mon Nov 13, 2006 8:43 pm Post Subject:
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
