DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
washing machine
This topic originated from the How to page called Installing a washing machine
Click here to return to the page called Installing a washing machine.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
dave_a1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 12:01 am    Post Subject:
washing machine
Reply with quote Thanks
My washing machine doesn't fill with water. This has just started happening. It will fill with 2 options and only to compartment one, whereas before it filled to compartment 2. It doesn't complete cycles as when it should be filling it just stops. Both fill pipes are fed from the hot water pipe using a Y. I have a bolier that heats the water as it runs through. The dishwasher is connected to the cold watre supply. Is there anythign I can do.
This was a waste of time
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
libby lou lou
from United Kingdom
Thanked: 1 time
PostPosted: Tue Nov 14, 2006 5:19 am    Post Subject:
yes, and your washer is?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Nov 14, 2006 6:28 am    Post Subject:
way to go, libby lou lou
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
dave_a1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 6:18 pm    Post Subject:
Its a SMeg
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Tue Nov 14, 2006 6:56 pm    Post Subject:
OK it's a Smeg. Now how about a model number?
In general, why have you connected it to the hot supply? It can't do any cold rinses nor can it do any washes cooler than your hot water.
Back to top
 Alert Moderators
dave_a1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 7:17 pm    Post Subject:
It does'nt have a model number. It was plumbed in by the builder not me. It's only a couple of yers old
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Tue Nov 14, 2006 7:27 pm    Post Subject:
It does have a model number. It will be on the machine somewhere, inside the door? inside the filter cover? on the back?
As to the problem you're having you'll need to check the fill hose isn't kinked and that the fill valve is opening.
Back to top
 Alert Moderators
dave_a1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 7:46 pm    Post Subject:
I give up
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Tue Nov 14, 2006 8:33 pm    Post Subject:
Without a make and model it's almost impossible to try and diagnose a problem. Different models have different methods of control and different common faults.
As you didn't provide any information we had to ask for it.
I've pointed out a problem with the way it's connected to the water, I've suggested a possible cause to the problem.
Have you rectified anything, checked anything?
Your response " I give up" makes me wonder why I bother trying to help.
Back to top
 Alert Moderators
dave_a1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 8:47 pm    Post Subject:
You didn;t you were asking questions that didn;t match the scenario. I'll find someone without so match attitude! icon_evil.gif
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Tue Nov 14, 2006 9:03 pm    Post Subject:
Fact. Make and model are important when trying to diagnose, for the reasons I've tried to explain to you in earlier posts.
Observation made regarding the plumbing arrangements.
Response. "It was the builder".
Fact. General advice given as to a likely cause.
Response. "I give up"
Look closer to home for the attitude. I've tried to assist you and your response has been nothing short of rude.
I have no wish to enter into any further dialogue with you on this or any other matter.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Washing machine - not filling with hot water 4 380 Fri Mar 14, 2008 5:20 pm
Zanussi Washing machine jetting water in wrong compartment.. 5 400 Tue Mar 18, 2008 11:11 am
Washing machine door not opening 2 320 Wed Mar 19, 2008 11:27 pm
dry run washing machine 4 180 Sat Mar 22, 2008 12:24 pm
indesit wia 121 washing machine, door locked while open? 2 460 Tue Mar 11, 2008 4:51 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
