Filling of Holes in Wall....Help
10 Oct 2006
Hi there,
I am currently decorating my hallway and have taken the banister fitting out of the wall, leaving behind some deepish holes. Now obviously i am not going to pack these with pollyfilla, any recomendations on what i should use?
Two of the wholes have breeze block behind them and two have brick.
Any help would be much appreciated and if i can get the filler from B&Q that would be a great help as i need to have this complete by the end of the week.
Thanks in advance
martin
.......or you can get one coat plaster for repairs. Depending on make I think they will fill holes between 1-2" deep. Check out the instructions!
Only thing I found was the surface finish was good but not brilliant so I had to sand it down slightly which can be a bit messy. That said, perhaps I just didn't smooth it very well !!
Nick
PS definitely available at B&Q cos that's where I got mine.
I agree. B&Q sell the Thistle General Purpose plaster (It used to be 'Blue Hawk'). I am just renovating a house and it is the fastest way to fill large irregular holes - where normal plastering techniques are not justified. Get yourself a decent random orbital sander with variable speed - very cheap ones are available from DIY stores and one of those will make your jobs much faster.
The finish will be smooth enough for good quality emulsion, which will fill minute scratches.
It is possible to use a float and water to get a very smooth final finish with this plaster. And it will remain in place at up to 50mm thickness!
