dishes not dry
14 Nov 2006
I have an AEG dishwasher and the dishes won\\\'t get dry. I\\\'ve heard that the \\\"elements may be out\\\". What does that mean? Any other ideas of the reason for the problem? Thanks
Does it get the water hot when it is washing? If so, the heating element is working.
Look in the instruction book to see if yours has a hot-air drying cycle (some don't) or if the drying cycle can be turned off to save electricity (some can) and how to turn it back on again.
If it does get hot when washing, open the door a little at the end of the final wash to let steam escape. The dishes willl be so hot that they will steam themselves dry quite quickly.
Heater, thermostats, wiring. Only way to diagnose it is to get the meter out and start checking things.
thanks for the ideas. The water does get hot and I have turned off the hot dry to save money. I will check things with the meter.
If you've turned off the hot dry then it won't dry. Turn it back on and see what happens
