Float Valve won't shut off
14 Nov 2006
Surrey
New to site please excuse if in wrong forum.
I have a standard bottom fill toilet cistern. It has been in about 2 years. The valve would not shut off and kept overflowing. I went to Wicks and bought a replacement unit. All plastic. This one also keeps overflowing, although not as quick as the original one. Neither has a flow regulator spiral as its used off a loft CWT.
Its a real puzzle. I am open to suggestions as I dont the there was anything wrong with the original valve when I inspected it.
Is it a torbeck inlet valve, if I recall these are an equilibrium valve
Pete
Yes I had a problem myself a while ago and am racking my brain as to how I sorted it.
Try filling it up untill it overflows then turn off at service valve and push the float up and down a few times then slowly open the service valve.
I think that was how I sorted it out.
Good luck
Pete
Thet are very sensitive to grit and dirt (possibly also flakes of limescale).
If there has been some work done on the mains or incoming pipes in house (or if there is drowned wildlife in the cistern) that could cause it.
Take it apart and see if it is clean.
Thanks Fluffster it worked exactly to your instructions. :D
Also sound advise JohnD
Cheers
Lewis
