Hope someone may be able help. I am losing about 1 bar of pressure overnight from my Worcester 240 combi boiler. The system has been unused for about a month whilst some other works have been going on and several of the radiators were removed for the decorator and were later reconnected.
I have initially checked for any leaks at the boiler connections and at all pipe connections to the radiators, but I can’t find any leaks at all.
Has anyone any suggestions on what the likely cause of the pressure drop could be, particularly as there is no evidence of water leakage. Is it worth putting some 'leak sealer' in anyway, just to make sure that there are no leaks where the pipework is not visible and do these leak sealers actually work? I saw some in B&Q yesterday for about a tenner and Screwfix Direct do this one
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=102633&ts=84274&id=37884
I would be very grateful for any responses as I really do need to sort this problem out. Cheers.
Mr M
Mr M
