Hi there, I live a council ground floor flat and I've just paid for my own kitchen upgrade with new sink and mono block tap. Problem is that my hot water pressure is running quite slowly, and the cold is running good. The hot water is supplied from a tank in an airing cupboard not much higher than the hot taps themselves! Also the mono block pipe fitting tapers from 15mm down to 10mm copper pipe. The cold is direct mains fed!
The hot water pressure in the bathroom is Ok to the bath and wash basin, however these are single taps with 15mm connections.
I tried turning off the cold mains 'stop tap' to see if the hot would then run any faster out of the tap on the kitchen sink but it didn't. This was to check if the mains pressure might be overpowering the hot - but it made no difference.
Now I’m thinking of fitting a home booster pump, but I’m looking for ideas / help? Anyone advise?
Please get in touch!
