Joined: 16 Nov 2006 Posts: 2 Location: Tyne and Wear, United Kingdom Thanked: 0 times
Posted: Thu Nov 16, 2006 12:48 pm Post Subject:
Watertight Bathroom Tiling
Had a quote for getting my bathroom walls and floor tiled - the bathroom has a corner shower so making sure things are watertight seems important to me.
I did a little research on the net and found you can get various membranes and specialist adhesives like Ruberoid - however my builder/tiler/etc said they would simply PVA walls and floor prior to tiling.
Would this be sufficient to ensure I am watertight?
It\\\'s particularly important to me as I am in a 3rd storey flat and don\\\'t want wet neighbours
Posted: Thu Nov 16, 2006 5:08 pm Post Subject:
thanks for the advice!
It's worth getting it done right for an extra £60
Why why why why WHY do people try to ensure you they're doing a job right when in actual fact they're going to be causing you long term problems....sigh
Joined: 18 Apr 2006 Posts: 280 Location: Cambridgeshire, United Kingdom Thanked: 0 times
Posted: Fri Nov 17, 2006 9:52 am Post Subject:
If you have plasterboard walls you might want to consider that it may be about the same price as the kit to replace them with aquapanel.
Aquapanel would be the proper way to go if this is the case.
I bought a BAL WP1 kit, but wish i'd just ripped the plasterboard off and used aquapanel instead.
The BAL WP1 kit is there for convenience in my view.
If you want less disruption, then go for the kit or an equivalent.
Shop around though, £60 from Topps Tiles is expensive!
(You should be aware that I'm not a professional, I'm just commenting based on doing my own bathrooms at the moment)
I sometimes wonder if this whole board is run by Topps Tiles
Joined: 26 Jul 2006 Posts: 71 Location: Kent, United Kingdom Thanked: 0 times
Posted: Fri Nov 17, 2006 11:02 am Post Subject:
I asked in B&Q about the waterproofing the other month and was told to use gloss paint on the wall first, before tiling, so the water wouldn't penetrate into the wall beneath the tiles.
What's worrying is that some people will take this advice...
Joined: 20 Aug 2004 Posts: 2001 Location: Surrey, United Kingdom Thanked: 6 times
Posted: Fri Nov 17, 2006 4:08 pm Post Subject:
James, the aquapanel will not stop water!
It will however not deteriorate if it comes into contact with water so it still needs to be tanked to make a watertight barrier. The tanking seals all joints and corners as well as the surface.
If I'm doing a new wall then its aquapanel and then tanked.
Joined: 19 Jun 2005 Posts: 5141 Location: United Kingdom Thanked: 0 times
Posted: Tue Nov 21, 2006 6:30 pm Post Subject:
in a shower wet area the wall/substrate needs to be Tanked ..as I an jase have said ...
btw the bal tanking Needs 24hrs to dry , I seem to remember another make being ready to tile in a few hrs maybe this is the one/Dunlop?
always used Bal gear professionally ...
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
