timmo69
Joined: 12 Nov 2006 Posts: 6 Location: Norfolk, United Kingdom Thanked: 0 times
Posted: Thu Nov 16, 2006 1:18 pm Post Subject: cut into blue plastic water pipe beneath the kitchen sink |
Anyone know if its possible to repair the blue water pipe which is directly connected to the mains... I caught it whilst cutting through an old kitchen unit!! have turned the water off at the meter.. but was wondering if I could repair it myself without having to call out a plumber
Cheers
Tim |
corgiman
Joined: 25 Aug 2003 Posts: 9195 Location: Surrey, United Kingdom Thanked: 2 times
Posted: Thu Nov 16, 2006 1:46 pm Post Subject: |
should be able to buy a connector for it from plumb center or some such place __________________ If at first you don't succeed, remove all evidence you ever tried. |
BoxBasher
Joined: 01 Nov 2006 Posts: 998 Location: United Kingdom Thanked: 0 times
Posted: Thu Nov 16, 2006 3:11 pm Post Subject: |
Get down to your local plumbing merchants/DIY store (even B&Q or Wickes) and buy yourself an inline connector for Blue PE pipe, complete with stiffening inserts, should fit in quite nicely.
If its an incoming supply then it will probably be 25mm. |
