If you can get it dry enough for long enough you could try a dollop of silicone. However your best chance of fixing it cheaply without having to replace it might be the use of some self amalgamating tape.
also
I dont know what its called as it was in a plain white box but my m8 just gave me some putty. 2 colours that you mix together. Its supposed to stick to more or less anything even when wet. Apparently this stuff costs about £24 a shot! Does anyone else know what it might be called?
I had one of these to fix last week but I was lucky. I managed to prise the boss off and remake the joint with solvent cement. Fortunately where it was located it wasnt too much damage when I got to it from below by hacking off a plaster board
