DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Arial lead to earth voltage
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
kthomas7
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 18, 2006 2:21 pm    Post Subject:
Reply with quote Thanks
If I measure with a multi meter from earth to my aerial lead I get a voltage varies between 10v and 80v depandant on how mant TV’s are switched on. All TV\\\'s are connected to the same aerial distribution. But TV’s are on a different ring main, I can even measure a voltage to the gas pipes!!! Any idea what the problem is? somthing seems wrong.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Big_Spark
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 18, 2006 2:41 pm    Post Subject:
Nothing is wrong, this is perfectly normal as there is always some leakage to true Earth from TV tuners. nature of the beast.
Further, you will be able to measure a voltage from the main aerial lead to true earth if you check..that is why voltage is called Potential difference..it is the potential charge difference between two electrically conductive points, material etc.
Nothing to worry about at all.
__________________
I only do commercial and Industrial so Prescott can shove his Part P tax
Back to top
 Alert Moderators
kthomas7
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 18, 2006 8:10 pm    Post Subject:
Thanks for your comment. But it is enough to give a small electric shock. How do large multi TV setups get over this like TV shops. Where they could get some very high voltages. This voltage is also evident on Audio interconnecting leads on the surround sound amp!
It seams if I can get a electric shock (how I discovered it) I should be worried?
Back to top
 Alert Moderators
GaryB
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 18, 2006 8:37 pm    Post Subject:
As Big_Spark says, this is normal. It happens on any double insulated appliance and is caused by very slight leakage through the capacitors that are present to ensure EMC (Electromagnetic Compatibility) compliance. As you've noticed, the current is tiny and is only usually measurable with a high impedance meter. It's an induced voltage - basically leakage, and is a tiny current and not dangerous.
I work for a TV/VCR/Camcorder manufacturer and we get regular calls about it.
Take a look at:
http://www.unitechelectronics.com/sparks.htm
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Connecting multiple TV arial cables. 7 820 Sun Dec 12, 2004 4:00 pm
swa to gland plate, earth lead from banjo required? 6 460 Thu Mar 20, 2008 5:51 pm
Earth clamp on lead sheathed cable 7 420 Tue Dec 30, 2008 6:27 pm
plastic & lead 5 220 Sun Sep 14, 2008 4:39 pm
Kettle lead power supply to LCD TV 14 420 Tue Nov 11, 2008 9:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
