Hairline Cracks................
1 Apr 2004
Hello,
I have cut some holes in the ceiling( they are large square holes for speakers) I noticed after that there was around 3 or 4 hairline cracks near where I have cut out the plaster board, They are not strait cracks, so not the board joints, they are the Zig Zag type, and I have looked it is the skim and not the board cracked.
I have found the end of all of them and placed a tiny pilot drill in to stop them chasing any longer.
What is best to fill a crack like this?
Some say just a standard filler, as they should not move again.
Some say a flexible filler put on with a wet spatula ( can you put normal filler on top if you don’t get it flush?)
Thank you
Darren
Whatever you use I reckon is going to end up showing..ordinary filler might crack again, you get a lot of movment in a ceiling...in fact caulk might crack too.
Id use ordinarly filler and then line the ceiling
Hello
This is not the other cracks I was talking about, but where I had cut holes.
Darren
sounds like the plaster has blown where you disturbed it cutting the holes..Or. You got the bass up on the speakers :LOL: :?: I would'nt worry too much as long as they are, only hairline. Polyfilla interior is good for this. Dont leave too much on surrounding areas.. myself I press a dollop into the crack and scrape off with me filling knife leaving no filla on surrounding area.. when it goes off a bit you may notice the filla shrinks into the crack. simply fill it again it wont shrink again and no sanding required.. ;)
good luck .
