DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Combi and New Rads
This topic originated from the How to page called Cutting off the water supply
Click here to return to the page called Cutting off the water supply.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
croman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 6:21 pm    Post Subject:
Combi and New Rads
Reply with quote Thanks
I want to move an existing radiator on a combi heated system which will require an extra few meters of pipe. If I turn off the mains cold feed, do I then need to drain down the system. If so and once done, how do I top the system back up. With the bleed valves closed on the rads, will the system re-pressure back to 1 bar when I turn the stop tap back on and open the re-fill loop at the boiler, and then do I keep bleeding and topping up ?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
MANDATE
from United Kingdom
Thanked: 10 times
PostPosted: Mon Nov 20, 2006 7:43 pm    Post Subject:
The mains cold water that goes into your combi comes out as hot water at your taps and the 'central heating' (CH) side is totally separate.
The CH side is filled and pressurised using a 'filling loop' from the 'mains side' Care is needed in filling the CH side, because the mains pressure is high enough to open the 'pressure relief valve'. If you only partially open the valve you can stop the filling as you see the pressure begin to rise and adjust accordingly
You will have to drain the CH side to work on the pipes. After filling you will as you say have to bleed the radiators which will cause the pressure to drop and you need to reinstate that pressure.
I understand pressure relief valves open around 3.5 bar so you could pressurise to say 2.5 bar on the initial filling.
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 8:03 pm    Post Subject:
2.5bar is probably to high for a 'standard' sealed heating circuit probably 1 - 1.5 bar (cold) will then rise to 2 and a bit when hot. Pressure relief probably rated to open at 3bar.
check boiler instructions for charge pressure (if its a combi or system boiler).
__________________
I am newly qualified, so don't rely on my advice get a second opinion!!!
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 8:08 pm    Post Subject:
I think he means 2.5 on the initial filling to bleed rads ?
__________________
You live to learn and Learn to live
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 9:32 pm    Post Subject:
fair point, i usually charge to 2bar on initial fill - bleed - fill - bleed, then set the pressure a tad higher than the book states to compensate for loss of pressure due to AAVents.
__________________
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 9:37 pm    Post Subject:
I usually sit by the filling loop and wait for the apprentice to shout
__________________
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 10:35 pm    Post Subject:
I've 'progressed' I used to run around and shout 'full' now i have to man the loop and shout 'full (to myself) icon_lol.gif
__________________
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 10:56 pm    Post Subject:
__________________
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 192 times
PostPosted: Mon Nov 20, 2006 11:53 pm    Post Subject:
If you cannot find a suitably qualified apprentice then you have to fit a 1.5 bar pressure reducing valve in place of the filling loop and bleed the rads yourself !!!
Tony
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 21, 2006 12:02 am    Post Subject:
If you got an apprentice that can't bleed a rad its time for him or her to go
__________________
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Nov 21, 2006 11:43 pm    Post Subject:
Agile wrote:
If you cannot find a suitably qualified apprentice then you have to fit a 1.5 bar pressure reducing valve in place of the filling loop and bleed the rads yourself!
...or just run up and down the stairs a lot...
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Combi Boiler - Balance the rads? 2 400 Tue Jan 01, 2008 9:01 pm
Combi Boiler - HW heats up Rads 3 160 Sat Oct 25, 2008 4:57 pm
COMBI-UPSTAIRS RADS HOT DOWNSTAIRS COOL. 6 620 Tue Sep 20, 2005 4:43 pm
New combi fitted, now clicking noise is heard through rads. 7 880 Sat Oct 01, 2005 11:11 am
Alpha Ocean 240 Eco Combi - Rads Warm When Shower In Use 2 220 Thu Jul 02, 2009 9:03 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
