DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Radiator Length Help
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
gmd
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 9:59 pm    Post Subject:
Reply with quote Thanks
I'm looking to replace an existing radiator that I have no idea how long it's been installed in the house. It appears to be 1520mm in length (from end to end) and 610mm high.
Would a replacement 1500mm radiator be a suitable replacement without having to alter the pipework (assuming distance from the wall is OK).
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 10:02 pm    Post Subject:
What pipes are feeding the rad 15mm or microbore?
__________________
You live to learn and Learn to live
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 0 times
you can by extension piesces that will extend the valves if needs be.
__________________
I am newly qualified, so don't rely on my advice get a second opinion!!!
Back to top
 Alert Moderators
Steady
from United Kingdom
Thanked: 1 time
PostPosted: Mon Nov 20, 2006 10:09 pm    Post Subject:
You should get the 1500 rad and if necessary use an appropriate extension piece - this will save you draining down also .
If you're going to drain the system down first tho' just remake the peipework to the new rad.
Extension pieces:
http://www.bes.ltd.uk/nav_graf/frames_cat.htm
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 10:10 pm    Post Subject:
Hang on you two, hes from Cardiff he might need me don't tell him too much
__________________
Back to top
 Alert Moderators
Steady
from United Kingdom
Thanked: 1 time
PostPosted: Mon Nov 20, 2006 10:12 pm    Post Subject:
Apologies for the bad link
You will have to use the link and search under Plumbing/central heating/radiator valves to find the parts required.
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 10:14 pm    Post Subject:
sssshhhh Steady
__________________
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 10:15 pm    Post Subject:
By the way gmd if you need a plumber my e mail is in my profile icon_lol.gif
__________________
Back to top
 Alert Moderators
Steady
from United Kingdom
Thanked: 1 time
PostPosted: Mon Nov 20, 2006 10:19 pm    Post Subject:
loads of work up 'ere in Manchester sime10- no need to chase customers. Traffic's sh*t tho'
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 20, 2006 10:31 pm    Post Subject:
__________________
Back to top
 Alert Moderators
gmd
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 21, 2006 9:13 am    Post Subject:
Thanks for the advice guy's. Any specific hints on what I need to get on the http://www.bes.ltd.uk/ radiator section website icon_redface.gif
Back to top
 Alert Moderators
Steady
from United Kingdom
Thanked: 1 time
PostPosted: Tue Nov 21, 2006 10:00 am    Post Subject:
On their website do a search for 'radiator extension pieces' and the first hit should say 'diverter valves' or something.
Click on this and look to the bottom of the page for a range of extension pieces.
You will have to work out which type and length suits your situation- depends on whether u are extending a TRV or normal lockshield valve as to which type to use.
The first ones shown (called adjustable) are for extending where the valve is a 3/4" union.
the second ones are for TRV's as it says.
the third type (non adjustable) are for either type of valve.
Hope this helps.
Back to top
 Alert Moderators
gmd
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 21, 2006 10:35 am    Post Subject:
Back to top
 Alert Moderators
gmd
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 21, 2006 1:33 pm    Post Subject:
Ok, who can tell me where I can find a 1500mm wide radiator.... Everything seems to be either 1400 or 1600mm in length icon_sad.gif
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Tue Nov 21, 2006 1:59 pm    Post Subject:
Come to Sussex then icon_rolleyes.gif icon_rolleyes.gif 3 mile Queues EVERY day on the way to Brighton FFS icon_rolleyes.gif icon_rolleyes.gif icon_razz.gif And not much work.......What could I buy for £250k where you are icon_wink.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
fitting new radiator in bathroom - match up length ? 18 1440 Mon Mar 26, 2007 2:26 pm
Thermostatic Radiator Valve pipe length 4 760 Sun Apr 22, 2007 5:22 pm
It takes ages for the hot to flow due to pipe run length.... 7 460 Tue Mar 13, 2007 12:57 pm
Length of LPG run 2 180 Mon Feb 19, 2007 1:12 pm
Longest flu length possible on a normal boiler 7 540 Sat May 12, 2007 9:08 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
