Cutting porcelain tiles
13 Aug 2006
Yorkshire
I am about to order some porcelain tiles but i would like to know how good they cut first. I was thinking of hiring a large bench tile saw from HSS.
They said that the blade would cut them, but could ask your tile supplier for a membrane to go on top, to stop them from cracking.(is this a common problem)
If the blade will cut them, do the tiles not want to brake the edges off when cutting the last inch or so.
I am not cutting many tiles, just inside the shower.
Hope someone can give some advice.
Graham
You can cut porcelain tiles with a reasonable quality manual tile cutter or one of the smaller electric wet cutters. Personally I cut with the manual unless its a double cut then do one with the wet and the other with the manual cutter as its quicker and cleaner.
Jason
Jason gives god advice.
I'm not tiling anymore, but when I was I had little use for a wetsaw - just a decent blade in an angle grinder did 99% of all my requirements.
The tiles we have seen are 600mm x 300mm. So would the size cause any problems. They probally would not fit in a manual cutter. I will have to go for the small electric.
Thanks for your coments
