DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Hot bath tap flow
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Fleaba
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 23, 2006 9:28 am    Post Subject:
Hot bath tap flow
Reply with quote Thanks
Just moved into my first house (and so am not DIY friendly yet!!) and this morning the hot bath tap is only a trickle. Its been absolutely fine over the past month. And also the tap feels a bit stiff. To try and figure out what was going on I put the cold tap fitting on the hot one and it works fine. Could it just be something as simple as I need to buy a new fitting?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
BoxBasher
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 23, 2006 9:49 am    Post Subject:
Does the hot tap operate in the same way as the cold, ie number of turns from closed to fully open, stiffness of operation etc?
When you say cold tap fitting do you mean the actual tap itself? OR just the internal mechanism?
Back to top
 Alert Moderators
Blasphemous
from United Kingdom
Thanked: 20 times
PostPosted: Thu Nov 23, 2006 9:56 am    Post Subject:
Yep.
You'll need a spanner/shifter or a PipeWrench. If using a Wrench you need tp be careful you don't damage the tap cover. Use a bit of material or better still, a bit of leather (such as a Chamois) between the wrench and the tap cover to protect the chrome finish.
Turn off the Hot Water. Use a screw driver to remove the head of the tap (the bit you use to turn the tap on and off). There should be a screw to the side of the head or it may be underneath a disk on the top of the head. Use your screw driver to prise out the disk to get to the screw then unscrew that screw.
Now unscrew the tap cover (Headgear Nut) using your wrench. Once that's off, unscrew the Headgear (the valve inside the tap). Both unscrew Anti-Clockwise BTW. You can replace the whole headgear. Pop along to B&Q with your old Headgear and ask the Plumbing section Geezer to point you in the right direction. Simply replace with new and replace headgear cover, tap head etc. Turn water back on. Job done icon_biggrin.gif
Back to top
 Alert Moderators
Fleaba
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 23, 2006 9:58 am    Post Subject:
The cold tap is nowhere near as stiff as the hot one. Also, the hot tap needs more turns to operate (the hot water is nowhere near as gushing as the cold water).
When I say I tried to the cold fitting on the hop tap I mean I swopped the actual tap ie. the bit I actually turn.
Back to top
 Alert Moderators
Fleaba
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 23, 2006 10:19 am    Post Subject:
Right, I hope its as easy as you make out! Im off to B&Q!
Thanks for the prompt reply.
Back to top
 Alert Moderators
Fleaba
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 11:59 am    Post Subject:
This dam tap!!
I still cant get the washer off this tap!!! Ive bought a mole grip to assist but no joy!! Its stuck tight!! Any suggestions anyone??
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 9 times
PostPosted: Wed Nov 29, 2006 12:03 pm    Post Subject:
I think you would be far better off going to a local plumber, or to an outlet that supplies taps.
I had similar type problem, went to the plumbers got help he then sent me to a tap shop.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Wed Nov 29, 2006 4:23 pm    Post Subject:
just need a pair of "tap revivers" from PTS or bum center or plumbase
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Hot water flow from all taps except bath tap 7 520 Tue Jan 11, 2005 11:01 am
v low hot water flow rate into bath 3 440 Wed Sep 20, 2006 12:48 pm
Fitted new bath taps, and the water flow is very poor 9 940 Fri Aug 06, 2004 10:47 am
Bath mixer tap - poor hot flow 15 6580 Tue Jan 03, 2006 11:07 pm
Bath flow rate and temp problem. 2 420 Tue Jan 10, 2006 10:14 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
