Boiler cutting out
23 Nov 2006
Shropshire
Can anyone help with a cutting out fault on a Glow worm space saver RF 40/50. Sometimes without any pattern it just refuses to fire up, It can happen when the boiler is hot or cold & I suspect the PCB. Whilst it had cut out tonight I checked the feed from the room thermostat & I had a voltage feedback at the thermostat output, If I disconnected the output wire the feed was only there when the thermostat was turned up (as you would expect) This shows that there is power coming from the boiler to the thermostat when it has failed, Is this the classic sign of PCB failure?
Does the boiler not fire up for heating and hot water when it is playing up?, does the pump run?
No the Heating , Hot water & the pump do not work when playing up. Am I right in saying the pump will only come on when the PCB asks it to?
Had the boiler serviced this century? ;)
Pump - depends how it was wired up.
Yes serviced late summer this year. Pump has been fitted for over 7 years so its not wired wrong (I dont think) & am I right in saying the boiler would fire up if the pump was not working but switch off after a few seconds due to the boiler thermostat switching it off?
