Gas cooker bayonet socket
12 Jul 2005
Bedfordshire
Hi all,
Final stages of planning my kitchen at the moment, want to set the base units this weekend. Thus I need to know how far my cooker will end up sticking out.
I've not had my gas man out yet to fit the cooker's gas supply (previously had electric cooker)
What's the regular install? 15mm copper pipe into a wall mounted brass elbow, then into an elbow bayonet socket? Thus total distance from the wall is approximately 80mm?
If I allow 100, would that be enough?
slip
good point spark123, not sure how i ended up posting it here...
mods!
________________________
Lynda, moderator
we do the nice things too, consider it moved
you dont have to put the elbow behind your cooker,put it on the wall behind the cupboard next to the cooker.leave access to connect and disconnect the bayonet.(leave the backpanel loose) the backplate is fixed 600 from floor
