DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Home made conservatory
This topic originated from the How to page called Repairing metal flashing
Click here to return to the page called Repairing metal flashing.
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
  View previous topic :: View next topic
Author Message
ChrisInman
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 26, 2006 9:24 pm    Post Subject:
Reply with quote Thanks
I have a home made conservatory on the house I\\\'ve just moved into, and it has a downpipe against the house wall going through the conservatory roof. The roofing is polycarbonate sheets, nailed to wooden joists. The flashing is knackered, it looks like kitchen foil type stuff. I want to replace, to make the room watertight, as it currently isn\\\'t. I\\\'ve seen a roll of flashing tape in the ScrewFix catalogue but am beginning to make some enquiries to do it properly - any advice from you learned folks would be most welcome and appreciated?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Mon Nov 27, 2006 4:04 pm    Post Subject:
Re: Home made conservatory
Shouldn't be nailed as the sheets need a expansion gap
Quote:
I want to replace, to make the room watertight, as it currently isn't.
The best and the easiest way is to fit a Easy-fit Glazing Bar, forget about using flashing tape
Other type of glazing bar here
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
ChrisInman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 27, 2006 4:37 pm    Post Subject:
Thanks for the useful feedback. Off the back of your response I've done a little research and I'll be buying new polycarb sheets and the glazing bars. Should sort the problem once and for all!!! Now on to the "hidden" gutter which is totally knackered ... I thought I'd place a piece of normal black plastic guttering in there, with flashing either side ... does that sound like something that might work?
Thanks again for the invaluable advice - much appreciated.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Mon Nov 27, 2006 7:14 pm    Post Subject:
Re: Thanks
Not sure what you mean, are you thinking of having a gutter all round the side as well?
__________________
Back to top
 Alert Moderators
ChrisInman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 27, 2006 8:26 pm    Post Subject:
Should have been clearer ...
Sorry, should have been clearer. There is a gutter along the far length of the conservatory. The left and right roof edges are raised, causing all the rain water to fall to the single hidden gutter. At one end of the gutter is a downpipe to the ground (no drain) - just dumps the water on the ground right there. The gutter seems to be clogged with all kinds of crap, so obviously I'll be cleaning it out as soon as the damned rain stops - but it looks like its been lined with foil type flashing, as opposed to any plastic construction. I was planning provisionally to clean it out, place a length of plastic guttering in there to catch the rain, instead of replacing the knackered flashing, which seems time consuming and prone to tears and crinkles, etc.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Tue Nov 28, 2006 9:24 am    Post Subject:
You seem to know what you're doing icon_wink.gif Also you can shape lead flashing to help the rain into the gutter etc
If you want to stick a photo, I maybe able to help you further
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
slipped tile, bird has made nest in roof 7 2700 Sun May 06, 2007 6:56 pm
can you drill old hand made clay roof tiles? 2 400 Tue Apr 26, 2005 2:04 pm
Is my shed roof made of asbestos? 2 820 Mon Dec 19, 2005 8:50 pm
conservatory lead flashing 6 540 Tue May 05, 2009 11:44 am
Replacing a polycarbonate conservatory roof panel 3 820 Fri Jun 19, 2009 5:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
