DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
squeaky stairs
This topic originated from the How to page called A new look for existing stairs
Click here to return to the page called A new look for existing stairs.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
PASCHA
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 12:06 am    Post Subject:
squeaky stairs
Reply with quote Thanks
we have just had a brand new set of stairs made and fitted and three of the stairs on the lower wind really squeak. The stairs wer made of pine. The carpenter said this will stop with age! surely we shouldnt have to put up with squeaky stairs?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Wed Nov 29, 2006 11:01 am    Post Subject:
Re: squeaky stairs
No you shouldn't,
Have look underneath if you can and see if the wedges are in tight (should be glue as well, not always icon_cry.gif ) If not, tap it in with a hammer for tightness. Check there are corner blocks, if not put some in with glue. Get someone to stand on the thread to see if you can locate the noise, if everything is in good order then a plywood with screw & glue under the thread will help and if you cannot get under the stairs, the only way is to drill holes and countersunk into the tread above the riser and screw it down into the riser then wood filler the screw heads. Sometime you can get away with running glue in the entire corner joint then lets it dried
Should really get the carpenter back though.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Squeaky stairs 3 980 Thu Dec 14, 2006 4:29 pm
Squeaky floor boards 3 1020 Wed Feb 06, 2008 12:16 pm
squeaky floorboards and fitted carpets 3 1480 Sun May 09, 2004 11:53 pm
Squeaky floors are driving us mad! 4 980 Sun Jan 04, 2009 6:33 pm
squeaky floorboards 7 6060 Sun Oct 28, 2007 1:35 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
