DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Basin Monoblock Tap Fitting
This topic originated from the How to page called Installing a bathroom sink
Click here to return to the page called Installing a bathroom sink.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
steamvalve
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 3:51 pm    Post Subject:
Reply with quote Thanks
I have recently fitted a new basin and monoblock mixer tap. I need some help on how to tighten the block to the basin. The tap came with a short piece of brass screwed rod, with a hexagon lock nut. The rod has a cross head recess in the end for a screwdriver. What ever I do I cannot get the thing tight enough. I screw the nut by hand as tight as it will go, but if I use a screwdriver on the rod to tighten it up - the nut backs off and gets looser. There isn't enough room to get in with a wrench. This must be a common problem. What do the professionals do?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
steamvalve
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 01, 2006 11:06 am    Post Subject:
Well i'm amazed none of you guys could help me on this one. I've done some further investigation and found out that you can buy monoblock tap backnut box spanners. These will do the job. http://www.hunter-tools.co.uk/product_info.php?products_id=1408 icon_razz.gif
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 32 times
PostPosted: Sat Dec 02, 2006 12:20 pm    Post Subject:
Well, I read your post and thought you meant the threads were stripped icon_confused.gif ...........good luck anyway icon_wink.gif
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sun Dec 03, 2006 12:42 am    Post Subject:
The stud is supposed to be screwed into the tap body before you offer onto the basin.
So, make the screw tight using the screwdriver, then install the tap, then use the box spanners that you're about to buy to do the nut up.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
French Basin monoblock tap hole size problem! 2 400 Thu Jan 31, 2008 10:54 pm
Hole in back of monoblock basin mixer 2 80 Fri Sep 11, 2009 11:19 am
Fitting Monoblock Kitchen Tap 6 1120 Mon Oct 10, 2005 11:14 am
monoblock tap fitting help please 5 120 Sun Jun 07, 2009 3:42 pm
Monoblock cold water tap - flow stopped 14 700 Sun Jan 15, 2006 7:40 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
