DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dimmer overloaded - any suggestions?
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
Duffledorf
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 8:29 pm    Post Subject:
Reply with quote Thanks
We have just installed two new ceiling lights with 12 bulbs each. It appears that this is too much wattage for the dimmer switch to handle as it keeps tripping to full power after a few minutes. Are there high capacity dimmer switches available or does have anyone have a work around?
thanks
Duff
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Wed Nov 29, 2006 8:38 pm    Post Subject:
What wattage and type are the lamps?
Are both fittings on the same switch (24 lamps on one switch)?
__________________
I downlights
Back to top
 Alert Moderators
Duffledorf
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 8:54 pm    Post Subject:
We currently have 12 x 60w bulbs in each and they are all on one circuit controlled by three switches around the room, one being a dimmer. They are standard ceiling lights.
I have just been looking at bulbs, the take the small screw candle bulbs, the smallest I have found is 25w each or a total load of 600W, could I get a dimmer that would handle that?
thanks
Duff
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Wed Nov 29, 2006 8:58 pm    Post Subject:
you can, also why not not screw in some of the lamps, seems pointless buying a light with so many lamps and then dimming it
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Duffledorf
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 9:03 pm    Post Subject:
thanks Breezer, but you could say that about any dimmer, just get a lower wattage bulb. icon_biggrin.gif
the main reason is that it is a very big room with a high ceiling and needed big lights. I hadn't really thought through the load issue. icon_redface.gif
I have come across a 1000 watt dimmer, but it is 1 gang 2 way and I need 2 gang 2 way!
Duff
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Wed Nov 29, 2006 9:21 pm    Post Subject:
i doubt you will get what you want in 2 gang, a bit og heat needs to be dissipated
__________________
Forum = Opinions
Back to top
 Alert Moderators
nozspark
from United Kingdom
Thanked: 3 times
PostPosted: Wed Nov 29, 2006 9:34 pm    Post Subject:
How's about using a 2 gang grid set up with remote dimmer packs. rexel senate do one at 1000W / 700Va ---- although the book price is almost £60 each + VAT
Back to top
 Alert Moderators
Duffledorf
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 10:22 pm    Post Subject:
Hi nozspark
That sounds interesting, could you give me some more details, or point me to the right place, rexel senate's website seems out of action at the moment.
thanks
Duff
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Wed Nov 29, 2006 10:24 pm    Post Subject:
Back to top
 Alert Moderators
Duffledorf
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 10:31 pm    Post Subject:
Thanks Spark123, but the lighting section isn't working!
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Wed Nov 29, 2006 10:41 pm    Post Subject:
it is now
__________________
Forum = Opinions
Back to top
 Alert Moderators
Duffledorf
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 10:50 pm    Post Subject:
Hi Breezer
I still can't get in, am I in the right place, I am clicking on products and then lighting, but just get a page of html code. Can you give me a link within the lighting section to see if I can access that?
Duff
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Nov 30, 2006 6:04 am    Post Subject:
lighting on that site starts at http://www.rexelsenate.co.uk/stratus
is an image from the page
__________________
Forum = Opinions
Back to top
 Alert Moderators
davelx
from United Kingdom
Thanked: 6 times
PostPosted: Thu Nov 30, 2006 8:43 am    Post Subject:
Duffledorf wrote:
Hi Breezer
Duff
Are you using Firefox? The page does not work in firefox for me, but it's ok in IE. - but I can't find any dimmers on the site.
Back to top
 Alert Moderators
nozspark
from United Kingdom
Thanked: 3 times
PostPosted: Thu Nov 30, 2006 11:29 am    Post Subject:
Just had a look at the senate web site..it's out of date.
I've scanned some bit out of the catalogue for you
No home page yet though!!!
____________________________
lynda, moderator
edited to show pictures
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Overloaded cables, anyone seen any really bad ones? 18 820 Wed Mar 14, 2007 8:05 pm
Hmm. I think this cable is overloaded... 37 1700 Mon Mar 19, 2007 9:05 pm
Overloaded Consumer Units 32 1560 Tue May 15, 2007 10:23 pm
consumer unit overloaded? 3 280 Wed Apr 02, 2008 2:31 pm
Overloaded Cables. 8 480 Thu Mar 15, 2007 1:08 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
