Plastering
12 Sep 2006
Sussex
Hi, I`m in the process of repairing the plaster on a wall - a narea of about 2 sqm. The thickness I need to repair varies between 6 and 2mm so i was thinking of using one coat instead of finishing plaster.
Can anyone tell me what kind of finish i can expect from the one coat (from B&Q).
Many thanks, Frank
Best using Two coats of Multi-Fiinish Plaster, as the depth of your patch is only 6mm.
One coat ? the grain is too sharp - to grainy. You never get a pro finish with that stuff. As said 2 coats of multi will do the job.
