DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Blocked Drains
This topic originated from the How to page called Clearing blocked drains
Click here to return to the page called Clearing blocked drains.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Burton900
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 30, 2006 6:30 pm    Post Subject:
Blocked Drains
Reply with quote Thanks
We have blocked drains at the rear of our property. We have three inspection covers and there is water and sewage seaping from under the covers. It started recently during this period of sustained heavy rain. We have had Drainsaid out on 2 occasions; firstly with the normal jetters and then with a larger tanker but they were unable to clear the blockage. We have contacted Welsh Water who say that it is a private matter although the Council have told us there is an adopted sewer next to the property. Any ideas what action I should take next with the problem to get the blockage cleared.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
BoxBasher
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 30, 2006 6:36 pm    Post Subject:
What age is your property? Do you share drains with your neighbours?
Back to top
 Alert Moderators
Burton900
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 30, 2006 7:21 pm    Post Subject:
The property is about 30 years old and according to Welsh Water the sewer is shared between 4 houses in our row.
Back to top
 Alert Moderators
BoxBasher
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 30, 2006 9:31 pm    Post Subject:
Right, only asked about age because different rules apply to pre-1937 houses with shared drains.
As a householder, you are solely responsible for any drain that carries waste from your dwelling. You are also jointly responsible for any drain that carries both waste from your dwelling and the dwellings of others.
This responsibility ends at the point where your pipe "drops" into the public sewer (the actual connection to the sewer is also your responsibility).
Welsh Water MUST come out and investigate any blockage on a public sewer. Ring them back and tell them that you have had all pipes that are your responsibility checked, and that your contractors have indicate that the blockage is likely to be on the public sewer (if that is what you have been told). From you OP it is just that your contractor couldn't clear it
Ring WW and they should come out and check their pipes, and the guys on site will be able to confirm if it is Welsh Waters fault (and clear it) or that it is your fault (in which case you may get them to do a foreigner and clear yours too, as their gear will be much more powerful icon_wink.gif )
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Drains blocked - but no drain cover to lift to sort it 10 240 Sat Feb 28, 2009 11:29 am
blocked drains 5 5460 Tue Jan 16, 2007 1:01 am
Blocked drains/ bad smell 4 600 Sun Nov 13, 2005 11:48 am
Blocked drains outside 2 680 Fri Jun 16, 2006 3:26 pm
Blocked drains 2 600 Fri Mar 02, 2007 2:36 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
